Real-time monitoring of power system analysis, unsure about any controllability
Need to view real-time parameters of the generation(which consists of a slip-ring induction motor and synchronous generator), transmission lines(where I characterise the lines for harmonic distortions, voltage variations, voltage spikes, high frequency disturbances, blackouts, phase faults, etc) and load(which consists of synchronous generator, driven by a DC motor, stabilised by an Automatic Voltage Regulator). This system must measure RMS and Peak Voltages and Currents, VA, VAR's, Watts, Power Factor, Spectral Analysis, Sag/Swell, Harmonics, Crest Factor, Distortion power factor, True Power, Phase Balance, Vector Plot, Waveform Capture(Waveform tracking, RMS level, Max/Min, Timed, Digital,
Manual), etc. I've got a AC current-, AC Voltage-, Active Power- and Reactive Power Transducer. Don't know which DAQ board, signal conditioning, breadboard connector and ribbon I/O cable to use for this type of application.
(3,373 Views)
Greetings,
You will probably need to break this down into specific questions. Otherwise, it is difficult to provide hardware suggestions. Furthermore, a great place to start is the DAQ Designer. It is available HERE.
Spencer S.
(3,373 Views)
