Realtime System by DAQ6024E
I am going to setup a real time system based on DAQ6024E and real time PC target. Since I am  fresh in Labview, I am wondering if someboye tells me weather it's basically possible or not? I use a PC as real time target. Therefore, I boot up the system with pre-defined usb stick. The problem is that when the system boots up with stick the PCMCIA port is not active. Just as a bit of information, on  BNC 2090 which is contected to DAQ6024E, there is a small LED which shows that the device is on or off. In such the condition, this LED is OFF. That's why, I say the PCMCIA port may not be active in the boot mode.
Thanks in advance for you any help and hints,
Amin
(5,369 Views)
I do not think it is possible. LabVIEW RT for desktop PC does only support pci cards. For the usage of a pcimcia cards, you need additional drivers for that interface.
Best Regards
Johannes
(5,357 Views)
Dear Johannes,
Thanks for your reply. But Do you know any alternative to run such DaQ-card in real time mode?
Cheers,
Amin
(5,354 Views)
