Replication of a 9148 configuration
Is there a way to do a replication of the configuration of a cRIO-9148 ?
I need to be able to apply a specific configuration to a 9148 without LabVIEW is there a way to do that ?
(5,059 Views)
Hello SmileBoB,
If it is channel and module configuration then you should be able to do taht exporting a configuraiton file thank to MAX:
Files>>Export then choose you system and export.
Otherwise, even though I never did it on a 9148 (>>ethernet RIO) you can try the replication utility:
replication and deployment utility
let us know what fits your goal the most.
Romain DUVAL || RF & Semiconductor Staff System Engineer || CLA || CTA
National Instruments France
(5,054 Views)
