Reset Position SoftMotion Function Block
Hey all,
I am trying to reset the position on two axes to zero. I can highlight the block diagram and am able to watch the function blocks execute, but instead of resetting to zero, the encoder and stepper reset to -7166 steps or counts. This line of code has worked in other programs so I am not sure what is going on. When I manually execute a straight-line move to zero, they also move to -7166. I'm assuming there is something in settings or wrong with the encoder that is causing this.
Does anyone have a solution or something I can try to resolve this issue?
Thank you!
(2,643 Views)
How are you configuring the Reset Position function block? For more information on that function block, refer to the SoftMotion Help: https://zone.ni.com/reference/en-XX/help/371093G-01/nimclvfb/resetposition_00b10088/.
Brian.D
NI Product Owner
VeriStand
(2,609 Views)
