Run vi on host from RT target
I want to place the entire application on a RT target and on the UI.vi on the host computer. How can I open FP and run UI.vi from the applcation on RT target.
(2,519 Views)
You don't.  You design a communication scheme for your RT system and your host VI to communicate.  This is usually done with TCP/IP and/or Network Streams.
(2,516 Views)
Thank you. Ok so let's assume that I have a RT thread with event case to handle controls. And controls are on my Host. I can send them by Stream, but for now I want to do it with shared variables. I guess I can use user generated events. Is it good solution, or should I go in a different direction? Are there any NI training lessons of that matter?
(2,503 Views)
Personally, Shared Variables have only given me headaches.  Whenever I used them, I got weird timing issues and/or they were slow.  I prefer using the STM library with TCP.
For a really good in depth discussion, I recommend the cRIO Developer's Guide.
(2,472 Views)
