Running 3rd Party Code on a cRIO?
All,
As far as I understand it the newer cRIO models run VxWorks as a base operating system. Is it possible to compile 3rd party code onto these devices? For instance could we run compiled C code, a secondary web-server, a mysql database, etc? Basically is it possible to get a shell to the OS and use it as a general operating system?
Ken
(3,356 Views)
Hi Ken,
Obviously anything is possible with enough time and work, but I would like to hear a little more about what you are thinking about doing.  We have a lot of different solutions to any given problem, and I would like to make sure you are using the right tool for the job.
Justin Parker
Product Support Engineer
(3,327 Views)
Hello Ken,
If you haven't seen it already you may find this devzone article useful, http://zone.ni.com/devzone/cda/tut/p/id/5694#toc4.
You may also be interested to know that you can access the FPGA from C code using the C Host Interface, http://zone.ni.com/devzone/cda/tut/p/id/8638.
Let me know if you have any other questions,
Sebastian
(3,317 Views)
