Running real-time and FPGA at boot.
Hi All,
I am running the NI 9401 cRIO with Labview 2011. I have an application that stores data at the FPGA level via DMA and then transmits this data to my host PC via the real-time OS. So I have three main VIs, titled simply as PC_Main, RT_Main, and FPGA_Main. The FPGA has a build specification and under RIO Device Setup, I have "Autoload VI on device powerup" selected. I do believe the FPGA is running at boot up.
Now my issue is getting the RT to run at boot. I have created a build specification called RPDT that uses RT_Main as a startup VI.
I build this and then choose "set as startup"
But I must be missing a step, because when I run my PC_Main VI, nothing happens. I should see data being collected. Everything works when I run RT_Main.vi as an opened VI, but I can't get it to run at boot. What am I missing here?
Also, related to this, what does my state of RPDT mean with respect to being able to run PC_Main.vi? I mean that do I always have to be connected through the project by right-clicking and "connect"? My end-game is to make PC_Main an exectuable and then everything runs at launch of this VI.
Please let me know if there is any other information I can provide. Also, I've already referenced:
http://forums.ni.com/t5/Real-Time-Measurement-and/Run-code-on-host-PC-RT-target-and-FPGA/m-p/1058339...
I followed this, but I am having an on the host side with the open application reference blocks, and strict VI reference. When I actually did get it to run, I still was unable to collect any data, as if the RT VI was never executing.
Scott
(6,058 Views)
Just to be sure - after you set the build specification as "Set as startup" you are first deploying it and then restarting (software reset or power cycle) the cRIO ?
(6,052 Views)
Thanks for the reply.
Yes, I deploy then restart. When I deploy RT_Main, it says deployment is successful. However, after a chassis reboot, when I try to deploy PC_Main, I get this:
I don't understand why this conflict is happening...
Thanks for the support.
(6,032 Views)
The conflict means that you have an executable already running in the target calling that VI. If you then re-deploy, it will have to close and reopen again the application. As far as that, it seems it is running. Could you try to add a heartbeat code in the RT Main VI to make sure the application is in fact running?
I've seen cases where the RT executable won't run because a particular object in the front panel or function is not supported as an executable. For example, a type definition in an RT executable. This article details some other steps we can try to get the application running for these cases.
(6,019 Views)
