04-10-2013 02:11 AM
Hello everyone,
I am trying to export several neural networks model from simulink to the SBRIO 9631. I am using the simulation interface toolkit in order to achieve it and i have started with the sinewave model, downloaded from the http://www.ni.com/white-paper/11654/en.
After installing the toolkit( Windows Xp 32bits, matlab 2011-a 32bits, labview 2012 and SIT 2012 too), I add the path in matlab to the SIT directory and i start the server in matlab. I can see the message about the port is started and I proceed to build the dll. I configure the solver to discrete steps with a 0.005 length and I choose the nidll_vxworks.tlc for target system. I process to build and i have this error:
Solved! Go to Solution.
04-10-2013 10:17 AM
I have installed the matlab 2008b and it runs. It is strange because in the compatibility document the 2011a version appears to be compatible. Anyway, with an older version runs without problems
