SMB Connector D I/O on cRIO 9014
The manual states:
"The software that supports GPS drift-correction and other digital I/O through the SMB connector was not available when this manual was published. Please contact National Instruments for more information"
Through my project explorer I do not see any way to programmatically control the output of the SMB connector on the cRIO.
I only require one Digital Output line and would like to use this connector.
Is the trigger on the cRIO-9014 usable at this time?
William
(5,296 Views)
Hi William,
I'm happy to say that the SMB connector on the cRIO-9012 and 9014 can now be used as a digital I/O line.  VIs to set, get, read, and write the SMB pin mode, along with example code, are attached in "901x SMB 8.2.zip."  You can ignore the search for vx_exec.out when opening the examples.
The KnowledgeBase article Using the SMB Connector for Digital I/O on cRIO-901x Controllers provides more details on drift correction if you decide to someday use the SMB pin for that purpose.
Jennifer R.
(5,280 Views)
Excellent.
This will do just what I require.
Thank you,
William
(5,267 Views)
How can I use the SMB connector of 9014 in LabView 8.5? These vi's do not work without vx_exec.out.
(4,860 Views)
Please create a new thread for this post--this thread is no longer in use. Also, please refer to the knwoledgebase article referred to by Jen R. It tells you about how to deal with vx_exec.out. you basically need to ignore that item in the search.
Ipshita C.
(4,825 Views)
