Saving datas to CompactRIO's memory
Accepted by Gilfoyle
@sefaa wrote:
What about my startup idea?? Is it correct?? I mean I did not use CompactRIO without computer, so I do not know what to do. The solution is to make the VI at Target side as startup and deploy it so that when the CompactRIO is powered on, it will start to log datas automatically??
That would be a simple thing to try if you had hardware.  But, yes, you just have to compile and deploy as startup and the application will run as soon as the cRIO boots up.
Message 11 of 11
(499 Views)
