Scan Mode using cRIO 9063 with analog input - problem in different data types connection
Hi guys
I hope you doing well
I'm Moh'd Wawi from Palestine
I need your help if you please, I'm working on NI cRIO-9063 with NI 9225 analog voltage input card, I'm using (Analog Input Getting Started Example in labVIEW example finder) and I want to display the grid waveform as oscilloscope (220Vrms and 50 Hz) in order to monitor the network and this will done using MRA-DWT to detect the network disturbances. Indeed I displayed the sinusoidal waveform but I still need to use the MRA-DWT Express VI ( I tried to but failed ) so I need your help here how can I connect the analog input terminal with MRA express VI (the data type of wire is different)??? you can notice that in attached pictures
Thanks in advance
greetings from Palestine ^_^
(3,027 Views)
Just "Connecting" is not difficult as below.
But I guess above doesn't resolve your problem. The express VI requires waveform data, it means that valid array data is required. Do you have it in your application?
Certified LabVIEW Developer
GCentral
(2,972 Views)
thanks a lot
I tried what you mentioned but it didn't work
yes the express VI requires waveform data as seen in the picture.
I don't understand what you mean ?!
thanks again
(2,951 Views)
I cannot understand "it didn't work".
The data type looks match, what does prevent your operation...?
GCentral
(2,933 Views)
when I press run
it gives this message
can you help please
(2,919 Views)
Lack of information causes confusion.
The problem is caused by Shared Library (SV). Confirm which library include the SV.
GCentral
(2,907 Views)
good evening and thanks for following
my code is working properly but !! when I insert the express VI (Multiresolution Analysis Discrete Wavelet Transform MRA-DWT) as mathematical tool it gives me the message (I attached in previous reply) to confirm me that there is an error
(2,880 Views)
