Scope of Single Process Shared Cariable
I have a framework for my application. Part of the framework depicts a common module for all my other systems (cRIO).
Therefore i created library for this purpose. My module involves communication between 2 loops. Therefore i used single process shared variable. But i wasn't able to create shared variable on the library.
"File-> New -> Library"
Hence i created an empty project and created a new library (lvlib) and added in the shared variables which falls within the hiercharchy of the lvlib. Everything works fine till then.
To move further, i created a new project, with 2 cRIO and have a RT build specification which includes the lvlib. But the single process shared variable wasn't included.
I read an article which says shared variable only house in the project scope.
https://www.ni.com/docs/en-US/bundle/labview-real-time-module/page/sharing-data-using-shared-variabl...
Is there any work aroud?
If not, i've to replace it with global variable.
Many thanks!
(3,078 Views)
Not sure what you are trying to do...can you show us your project?
(3,071 Views)
