03-01-2006 05:51 AM
03-02-2006 03:48 AM
Hi Simone,
the serial communication is not a deterministic operation also in Real Time applications. Using serial code on the Time Critical VI can cause jitter, so the determinism could not be respected. It doesn't mean that it's not possible to achieve your speed specification, you have to try to develop your application (serial and "main task") to evaluate time behavior.
I don't know which Labview version you are using and what "main task" means, but I can suggest to you to use Timed Loops to manage priority execution.
I hope this helps you.
MarcoC
03-02-2006 04:31 AM
Thanks Marco C,
I'm using LabVIEW 8.0 Developer Suite with Real-Time Module (ETS);
I've to develop an Hardware in The Loop System (HIL), and every 10 ms I must send data to a GPS costellation simulation system with RS232; the amount of data is low but if I can't control the serial communication in the real time system is a very problem; the solution to develop a (U)AR(T) realized in LabVIEW-FPGA it has too time and cost expensive at this moment and I would try a different solution.
The main priority task is the computation of a single step in the aereodinamic simulation model of the flight device.
Simone
03-02-2006 06:23 AM
Try to built a VI that peforms only the serial communication and study its time behavior. Try also to increase the priority level of the VI (up to High Priority) to evaluate the improvings.
However it's not easy to help you through forum, so I suggest you to call NI Technical Support at 02-413091 to talk with an application engineer. You can ask about me.
Marco Castellano
