Serial to Ethernet Conversion in FPGA
I am using Crio with a custom C series GPRS module for Data communication. But the issue is i can transfer the data in Serial format, means I am not able to access my cRIO through GPRS.
My question is can i access my cRIO using custom C series GPRS module using any Serial to ethernet conversion, as i access it using LAN.
(4,943 Views)
Hello SCADA,
Are the cRIO and the host computer directly connected through an ethernet cable?
Regards
Akshat Jain
(4,829 Views)
Hello ,
You can use it with the convertor. Which 3rd party module are you using ? Please elaborate a little more on the configuration .
(4,801 Views)
The interface available with GPRS modem is RS232 via C series module interface available on rio Chasis.
So  is there any FPGA software algorithum conversion technique to virtually convert ethernet port of RT on RIO chasis port.
(4,783 Views)
I did a similar setup a while ago with an older GPRS module. I had success with a third party standard serial to ethernet converter. Make sure to setup the unit properly and check that all data settings are matching.
(4,169 Views)
