Simple Stopwatch/Timer for front panel (resetable)
Hello!
Thanks for this fast reply!
I will read those links and if there's a problem, I'll be back.
Message 21 of 26
(3,672 Views)
Hey!!.Try this VI
Message 22 of 26
(3,166 Views)
I found one a few years ago that works fine.  I tried yours but it won't run on version 8.6.
Thanks anyway.
Todd Munsell
Test Cell Manager
Wood Group Pratt & Whitney Industrial Turbine Services, LLC
Plattsburgh, NY
Message 23 of 26
(3,159 Views)
Sorry for that.But it works perfectely in LabVIEW 2014.Try in that version if you want.Smiley Wink
Message 24 of 26
(3,152 Views)
I try your stopwatch.vi but the indicator blinking, do you know where is reason for that.
I builded my own applications and I noticed the same problem. If I run it as builded application this is really disturbing.
Message 25 of 26
(2,818 Views)
Hi @klemenTrpin,
For workflow purposes and in order to have your issue seen by more people in the forum I would recommend that you make a new forum post instead of commenting on an old one.
The forums are most active on the newer posts and someone will be more likely to reach out on a new post.
David
Message 26 of 26
(2,809 Views)
