Simple measurement of an encoder?
Sorry if this is redundant. I've searched here and the examples. I see several examples that measure quadature encoders and do period measurements, but I am wondering if there is some very simple logic to do the following:
Count the number of rising edges
Keep track of the time
At a specific time interval (user controlled) display the total counts
Reset the counts and the timer and start again.
I just want to know the number of pulses that I saw over xx microseconds.
For whatever reason I'm having a brain block lol. This should be very simple.
I'm using the FPGA of a cRIO and a 9411 card. It does have the quadature inputs connected but I don't think I need any more than one channel.
In the end I will be calculating velocity with a user defined time interval.
Jeff
(4,670 Views)
Have you looked at the shipping examples
c:\program files\national instruments\labview 8.2\examples\compactrio\fpga fundamentals\counters
Let us know if these work for you
Preston Johnson
Solutions Manager, Industrial IoT: Condition Monitoring and Predictive Analytics
cbt
512 431 2371
preston.johnson@cbtechinc
(4,664 Views)
Perfect! I knew that there would be an example somewhere in there 🙂
Thanks!
Jeff
(4,658 Views)
