Sine Generator in Realtime Scan Interface Mode (no-FPGA)
hello,
I´m trying to create an Signalcreator (Sine Signal) on my AnalogOut.
The Examples offered by Labview, are all on FPGA. 😕
I Added an part of my Project (including the TimedLoop) to show you where the Generator should be working.
I´m not sure how to generate the correct Signal (sinus with changeable frequecy), depending on the Periodtime/ScanTime of the timed-loop.
would be great if someone could help me.
Greetings
(5,988 Views)
Accepted by topic author MarMo
Hi  Marmo,
Point by Point operations are very suitable for generation Signals on RT level. You will find the VI in signalprocessing/ point by point transformation.
For each iteration of the loop a scalar value will be generated be aware of frequency settings for the VI.
You configure the Delta t via the timing VI.
Please check the attached screenshot.
Kind regards,
Rup
NI Germany, AE
(5,962 Views)
Thanks a lot.
found that example day before :))
I connected it this Way....(using the Timed Loop Time)
Greetings
(5,952 Views)
