Slow Application if compiled and Deployed to CRIO
Hello all
I've developed an application that uses 16 channel from 4 9233 modules (the controller is 9004) onto disk.
The application works perfectly if run in development environment (LV 8.0.1) but it's incredibly slow if compiled with application builder and deployed to the RT controller (of course same application and same everything). It's so slow that the FIFO fills up and I can collect data no more.
Is there any workaround?
thanks in advance
giovanni
(3,415 Views)
Hi, we are handling a similar support call through our system engineers team, I suppose it is your application, if this is true we go on working in that way and we'll post something here when we'll find a solution.
If you are not already in contact with NI Italy try posting your project here and I'll be glad to test it to see if I can reproduce this odd behavior.
Regards.
NicolaC.
Nationa Instruments
(3,391 Views)
