Slow Realtime Target Host Communication
I'm starting with Labview RT.
I would like tor read out a thermocouple signal, sending it afterwards to the Host VI. It works but far to slow.
I've tried to look at CPU, Memory Usage but there comes my second problem. The DSM does'nt contain the functions it should.
Am I missing a special configuration?
(5,078 Views)
Accepted by topic author Maloya
Network Published Shared Variables are slow, especially in a high traffic network.  I would recommend using a Network Stream and set up your own communications scheme that can handle the higher output rate.
(5,075 Views)
Thanks for the fast answer. A wait function works as well for those who are not interested in a high resolution.
I've opend a new thread referring to the dsm question.(http://forums.ni.com/t5/Real-Time-Measurement-and/dsm/td-p/3135168)
(5,069 Views)
