Smart camera 1722 and TPC 2106
Hi, I am making an application that uses a TPC2106, a smart camera 1772, a Micrologix PLC and a remote PC. The TPC is the HMI process and it should be showing the image and configure the visual field and cam parameters. The remote PC should be showing the remote panel, and sometime controlled the system. The control loop is deploying in the Micrologix. Shared variables are use to communicate the  NI components (except the image). My problem is showing the image in the TPC. Initially I think use a shared variable, but when I had created a shared variable for the image, it only had local scope (in the cam). After I think use a remote front panel, but the TPC does not support the LabVIEW Run-Time Engine (http://forums.ni.com/ni/board/message?board.id=280&message.id=5583#M5583). How I can show the image to the TPC?
PD: Since English isn't my native language, please apologize for my bad write.
(3,439 Views)
Hi navas,
You can't show images from a camera in a TPC 2106 or any other TPC that runs Windows CE.
Rodrigo Schneiater
NI Brazil
If this information was useful, please click in the 'KUDOS!' beside.
(3,348 Views)
