TCP error Proxy Caller
Hi
iam trying to run an application on cRIO-9012(i have connect cRIO on router) embedded.
which is simple TCP IP server client(NI Example).
But it gives some error like "Proxy Caller".
Please see the attached code(LabVIEW 8.6.1).
any one will be appriciated who will tell me what am i going to miss.
thanx for any sort of correspondence.
Message Edited by mazhar.ali on 09-01-2009 04:38 AM
Message Edited by mazhar.ali on 09-01-2009 04:39 AM
(4,288 Views)
Hi,  I dont see anything outright suspicious by looking at the code.  Do you have a specific error and the VI that is calling it.  Run it from the project with a front panel and get a screenshot.
Chris Bakker
SET Americas
CEO
(4,266 Views)
thanx
Chris Bakker
this exampl has no issue if we run this example simply to cRIO.
but when we run this with web service it gives error.
we have a web service and a server and we want to communicate between them via TCP IP.(which was done successfully on windows based machine) but when we try to run it on cRIO it gives error like Open TCP connection or Proxy Caller.
(4,257 Views)
mazhar.ali-
Please take a screen shot of your error.  We need to find out if the error is associated with your code, or possible with your web browser.  If this error is associated with LabVIEW, seeing the actual error message will assist in the diagnosis.
Mike S
NI AE
(4,227 Views)
