TDMS Advanced Open slows down over time on CRIO-9067
I am developing an application logging 9 different analog inputs and 4 digital inputs. I am using the cRIO-9067 to write this data to two different hard drives with one of them acting as a backup for the other. The test sequence is ran every 2s for 1 million cycles. A total of 2500 samples is collected for each of the inputs making a total of 32,500 values every 2s. Each cycle a new TDMS file is create. The VIs are attached that make up the data logging function.
The problem that I am seeing is that as the test progress the time required to open the TDMS increases greatly.
Any help with this problem would be greatly appreciated.
(4,362 Views)
Is there are particular reason why you would want to create a new file in every iteration? It would be far more efficient to create a single file, and adding the data to it in each iteration, instead of having to open a new reference in every cycle.
(4,345 Views)
The zip file contails 4 VIs and I couldn't open all of them. For the first 3 VIs, they miss some subVIs and for the "TDMS Config.vi", it doens't contain TDMS Open funciton.
(4,339 Views)
