THERMO READ 9211_TC.vi module ¿¿OUTPUTS??
we are using NI 9211_TC.vi module (THERMO READ), its inputs are cluster type containing (TC0,TC1,TC2,TC3, CJC & Autozero) and selectable type of thermocouple (type K in our case). ¿What about the outputs of this vi? if we read and placed a indicator of the array output, they are 8 elements. The first 4 of them seem to be temperatures 0 to 4 but we do not know what the last four are.....
Thanks everybody
(2,981 Views)
Hi Mallue
Actually the real size of that array is 4. Although you can see an eight position array indicator only the first four positions are filled.Those positions are for the four channels of 9211, besides you can see that the last four positions are disabled. This is normal . don't worry about it.
Belens
(2,967 Views)
