Test RF using R&Scmw290
Hello
I'm working on test RF using cmw290, i have downloaded the instrument driver rscmwgs (GSM Signaling), rscmwgg (GSM Generator), rscmgm (GSM Measurement)...
I think that those ones are the drivers to use for test GSM.
the problem that I found difficulties to chose some fonctions to configurate my cmw for this test,
for exemple what's the difference between rscmwgs configure generator state and rscmwgg configure generator state!
waiting for ur answers and thank you
(3,217 Views)
Hi Maria,
Where did you find the driver? It is hard for us to determine exactly what you're talking about if we do not have access to the driver/code itself.
Also, have you contacted the manufacturer of the device/driver? They might also have a better idea about how their driver works.
Stephen
(3,181 Views)
it's ok I found the solution, it was about delating some unecessery functions from the cmw's vis 🙂
Thank you
(3,038 Views)
