07-22-2010 01:27 PM
Hi all,
I'm a new LabVIEW user and I try to measure a temperature using a thermocouple and superlogics 8520 (as RS-232 to RS-485 converter) and a superlogics 8018 (8 channel thermocouple input module). When I use the DAQ assistant I have this message ''no supported devices found''. I downloaded the drivers from superlogics and tested all the connections but I still don't know why my computer don't detect my device. Probably I missed a step?
Jamat
07-23-2010 03:33 AM
Hi Jamat,
The DAQ assistant only supports devices that run on the NI-DAQmx driver which are the NI DAQ cards. I can see that the products you have are connected to the PC through RS-232. Usually you would use serial commands to talk to this. Superlogics have done the hard work for you though and have drivers available on their website at http://www.superlogics.com/downloads.asp?prod=787. If you download and install these you can use their LabVIEW functions to acquire data from the device but these still will not work with the DAQ assistant.
