Timed Loops with External Clocks
Hello All,
I was wondering if it is possible to create a single cycle timed loop which is clocked from an FPGA IO pin.  I am attempting to read high speed parallel data (10Mhz), perform a small amount of signal minimalisation and then transfer the result to a DMA FIFO for transfer to PC. The way that the parallel data is formatted is that there are 16 IO lines wired to the bus, and a 17th line for indicating a data ready status.  This is expected to come through at 10Mhz.  Can I use a timed loop from this 17th data line to ensure that my code runs at high speed?  For what its worth, I am using a PXI-7811 FPGA.
Thanks for your help,
Tristan
CLAD
Message 1 of 14
(9,081 Views)
What you are trying to do is use an external clock. Unfortunatelly you currently cannot use an external clock source in LabVIEW FPGA. I would recommend creating a derived clock that  matches the frequency of your external clock as closely as possible.
Eli S.
Message 2 of 14
(9,069 Views)
Thanks for letting me know Eli, that saves a lot of confusion! 🙂
Is there any plans to implement this in future releases?
Cheers,
Tristan
CLAD
Message 3 of 14
(9,064 Views)
Tirstan,
I am not sure whether or not there are plans to implement this on future releases 😞
Eli S.
Message 4 of 14
(9,056 Views)
Tirstan,
We are actively researching and working on this feature for a future release, so keep a look out for that. The type of application you described is exactly the type of problem we are looking to solve.
Thanks for your question
Rick Kuhlman | LabVIEW FPGA Product Manager | National Instruments | ni.com/fpga
Check out the new FPGA IPNet for browsing, downloading, and learning about LabVIEW FPGA IP Cores
Message 5 of 14
(9,046 Views)
Thanks for the info, I look forward to the newer versions!
Cheers,
Tristan
CLAD
Message 6 of 14
(9,031 Views)
Was this feature ever implemented?
Message 7 of 14
(7,767 Views)
Hi Kevin,
This feature was implemented in our FlexRIO line of products. Most of the FlexRIO modules have external clock line inputs that can be exported to a Single-Cycle Timed Loop (SCTL). As for the R-Series and CompactRIO product lines, there is not a direct way to export a digital input line directly to an SCTL. You can either derive a new clock from the base clock of the FPGA or, if using a PXI system, export the 10 MHz backplane clock to an SCTL.
One workaround that can be implemented is to have one SCTL reading a digital line, and another SCTL monitoring a local variable from the previous loop and checking for edges. I have attached a screenshot displaying a certain portion of code executing when the digital input has a rising edge (false to a true). This implementation will not have the accuracy of a directly exported clock; however, as long as you are using the default 40 MHz timebase for the timed loops reasonable frequency for the digital input, I don't believe you should miss any edges.
Best,
Tannerite
Message 8 of 14
(7,757 Views)
What is the benefit of going through a local variable vs. just reading it in the same loop?
Message 9 of 14
(7,613 Views)
Hi Kevin,
You can use one loop as well. If you are wanting to trigger multiple independent pieces of code, it could be useful to use a local variable to trigger other multiple parallel loops. I coded it this was for expandability; however, I think I overcomplicated things by adding two loops!
Best,
tannerite
Tannerite
Message 10 of 14
(7,607 Views)
