Trouble with recording c-scan ultrasonic programming
I am programming an ultrasound scanning system to perform a C- scan of biological samples. I have gone through the examples on ni website. but i am unable to understand the c-scan Vi and i am struggling to know what I should be connecting to x and y index and also to the intialize array?? i am using sigmakoki motion controller to move my transducer in x and y direction.
i have attached a file below pls see.
(pls pardon my ignorance i am in lifesciences and new to programming)
many thanks
(3,460 Views)
Hello Ultrasound,
I would like to help you with your question.  I have had a quick look on the NI website, but I have not found a specific C-scan example.  Do you have a link for it so that I can find it?
If you are referring to the example you have attached:
  1. Have you written this VI yourself, or did you inherit it from a colleague?
  2. Which part of the VI contains the code your require help with?
  3. Have you seen any of the free training material online to help you teach yourself LabVIEW?
George T.
Senior Applications Engineer
National Instruments UK and Ireland
(3,446 Views)
