Two cRIOs in single project
I developed a project for cRIO 9053 device, which works fine. I also have cRIO 9063 chassis with the same modules and I would like to be also able to use it in the same way. I tried to add another device to project, but project explorer would not allow me to do that, since the devices have same IPv4 address (172.22.11.2) and I apparently can´t have 2 devices with same addresses in project. So, I tried to configure IP address of cRIO 9063. I am communicating with cRIO through USB. If I understand correctly what I see in the uploaded picture, cRIO has 2 network adapters, one associated with Ethernet and one with USB. I am communicating with cRIO through USB, therefore I need to change address of the second adapter. However, It does not seem to be possible from the network configuration window. My question therefore is, if it is somehow possible to change this address, or if there is any other workaround for using two cRIOs in single project with which I communicate through USB (other than creating whole new project for cRIO 9063).
Message 1 of 1
(2,088 Views)
