UI Options for Deployment
We're scaling our deployment from a single 9030 always tied to a developer machine to about a dozen, hopefully without requiring a dev machine for each instance.  I'm now trying to figure out what my options are for the user interface - we've been doing this by just hitting run from within LabVIEW, but now we're deploying.
Can you please help me better understand my options?
1) Install LV on laptops, continue to "just hit run".  I'd like to button it up a bit further, but this is an option.
2) Connect a monitor / keyboard / mouse directly to the cRIO-9030s.
3) Create a separate LabVIEW executable that I write that connects to the cRIO via e.g. shared network variables.
Are there additional options?  Is there an easy way to project the existing front panel UI to a web interface?  to a windows executable?
 - Eric
(4,396 Views)
I would suggest taking a look at the Replication and Deployment utility.
https://www.ni.com/en/support/documentation/supplemental/12/archive-of-the-real-time-application-dep...
(4,391 Views)
