USB-TC01 Temperature Sensor Control Using NI-VISA APIs in a C Application
I have a USB-TC01 temperature sensor, and i want to integrate it with Vector CANoe using C code.
In CANoe, the code will use the NI-VISA APIs to open/close and read/write data to/from the NI-VISA library.
So, i want to know the set of commands that should be sent to the NI-VISA APIs in order to send commands to the temperature sensor, and to read data form it.
(1,426 Views)
I'm hoping to do a similar thing with Python but I haven't bought the USB-TC01 to test. I've been using SCPI commands for the majority of my program so hopefully this can work for the both of us.
Full list of commands:
https://www.mccdaq.de/PDFs/Manuals/MEASURpoint-SCPI-Programming.pdf
you can try ":MEASure:TEMPerature:TCouple?" to read the temperature
hers what it says as an example
"The following example configures analog input channels 0, 1, 7 for
the default sensor and transducer type for the instrument and then
reads the temperature from these channels:
> :MEAS:TEMP:TC? DEF,(@0,1,7)
< 23323132c7ad9c0041bd99b647c34f800a
where:
• 23 = ’#’ denotes the start of the block response
• 32 = ’2’ is the length of the decimal number for the block length
• 3132 = ’12’ is the block length (that is 4-bytes per channel times
3)
• c7ad9c00 = –88888° C; this is the measurement value from
channel 0, indicating that the value is too low and out of range
• 41bd99b6 = 27.7° C; this is the measurement value from channel
1
• 47c34f80 = 99999° C; this is the measurement value from channel
7, indicating that an open thermocouple exists on that channel
• 0a = carriage return; this is the standard ASCII terminator"
If you could get back to me on if this works or how you managed to do it if you already got it done I would appreciate it.
If nothing else just confirmation before I buy that the USB-TC01 connects to NI-VISA would be nice.
(1,354 Views)
