Unable to click OK -- Data Binding using Shared Variable Engine
Hello all,
I'm facing a problem when I try to using Data Binding.
Actually, this particular variable is already bound but I'd like to change it for another variable and bind it again.
It should be pretty simple: on the control or indicator, right click ->Properties->Data Binding and select the variable that I want.
However, when I do that, somehow I can't click OK (please, see the attached figure).
It's really odd because the variable was bound before.
I was wondering if someone has any clue why it's happening.
Maybe something on the settings...
Thanks! 🙂
Message 1 of 1
(1,862 Views)
