Unable to connect to the fpga compile server
Hi, I keep getting the following message when trying to compile my FPGA code -> LabVIEW FPGA was unable to connect to the FPGA compile server....
System configuration:
Win 7 64
LV 2009 (32 bit) SP1
LV FPGA 2009 SP1
cRIO 9024
9114 Chassis
I am developing and compiling on the same machine with the cRIO attached through a wired router.
I've tried repairing the FPGA installation with no changes.
The attached screen shots are displayed in the order they are pasted
Any insight would be appreciated - thanks in advance!
Message 1 of 31
(9,141 Views)
Try this:
Why Do I Get FPGA Compile Server Errors?
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
Message 2 of 31
(9,123 Views)
Can you try using "localhost" instead of the ip provided?
Can you remote compile on another machine?
Also note that xilinx used by LV FPGA doesn't officially support Windows 7. Although this has been tested by National Instruments and should work, there could be issues. So its best to double check that you can compile on another system if at all possible.
Andrew E.
RIO Embedded Hardware PSE
CompactRIO Developers Guide
Message 3 of 31
(9,108 Views)
Thanks for your replies.
One interesting note is that when the compile server launched the status indicator displayed "Running" for just an instant beore it changed to "Idle" and then would not connect and then timeout.
I installed the FPGA software on my laptop - same OS, development environment, anti-virus, firewall settings, etc and it worked the first time out of the box with no problems or changes in configuration.
I suspect an installation problem so I am going to unistall the FPGA software and re-install it - I will update this thread when this is done.
Your input is much appreciated.
Message 4 of 31
(9,104 Views)
"DOH!" - I managed to fix this issue by changing a permission setting in my anti-virus firewall then re-booting.
Thanks for the help and sorry for the fire drill!
Message 5 of 31
(9,093 Views)
Wasn't that mentioned in the link in my initial post; just trying to understand how you resovled the issue...so please be sure to post the solution if it's different than the one mentioned, so others can benefit.
Adnan Zafar
Message 6 of 31
(9,080 Views)
Sorry,
Nothing to do with the port settings
I added the port as the link suggested but nothing changed so I deleted the port.
To resolve the issue I went into McAfee's advanced firewall settings and selected the option to allow the compile server full internet acces.
This fixed the problem immediately.
Thanks again
Message 7 of 31
(9,072 Views)
I have the same antivirus, and  I alredy do what you say, but doesn´t work, any other option??
Message 8 of 31
(8,745 Views)
Hi Emmanuelol,
What steps have you done so far?  What's the operating system that you're using?  What version of LabVIEW?
Jared S.
Applications Engineering
Message 9 of 31
(8,718 Views)
Hi, i already unactived the firewall, also the antivirus, my OS is windows 7 my version of LabVIEW is 2009 full development, i know that xilinx not bring support for windows 7, but do you know others alternatives for use the server compilation???mor the only way is use virtual machines??
Message 10 of 31
(8,681 Views)
