Unstable usb connection to a cRIO-9040
Dear all,
I have been developing a Real-time Labview app where cRIO-9040 is streaming data at 1MS/s from FPGA to the host computer via network streams. On one computer, the discovery of cRIO, deployment and streaming data works flawlessly (which is my office computer😕  ) . Once I move the cRIO to the lab, which also has a decent machine (bought in 2020) , the discovery of cRIO lags, each time I try to even switch to RT vi it would pop up a window that it's trying to connect to the target) and all my network streams work so slow that the RT FIFO's overfill very quickly. Both machines I connect to USB 3.0 port (according to the marking) and I have tried multiple ones on the sluggish machine with no success. Whenever I search for troubles in usb connection I get topics related to overload of cRIO machine or firewall issues, but here these both are clearly not the case as I have a machine where everything works and on the lab machine it works, but just slow and unstable. Would you have any advice on it?
PS I am going to try ethernet on Friday or Monday.
Thanks in advance,
Sergii
(2,040 Views)
Hi Sergii,
you have met an interesting problem. Was it solved?
Is the connection faster with Lan connection?
(1,935 Views)
Hi Tidad,
Yes, with LAN it works like charm. With usb on this particular machine is troublesome. So we just went for the ethernet connection.
Bests,
S
(1,932 Views)
Thanks for the information.
It would be good to know the USB behavior reason.
(1,929 Views)
I was unable to figure that out. Especially it was hard to troubleshoot because it was not completely broken. Just slow and time to time loosing connection to the computer. I have tried all version ports on this machine with no difference. What heard from electronics department is that in general USB-to-LAN conversion is rarely bug-free and in general less reliable than true LAN. So I went for it:)
(1,927 Views)
