Urgent Help: I cannot get any signal from I/O modules of my cRIO-9012
I was setting my compactRIO-9012 up. It is completing connected and is available at NI MAX and Distributed system manager. This means all of steps at NI guide(http://www.ni.com/gettingstarted/setuphardware/compactrio/) was succesfully done but there is no signal from mu modules!! All of cpu and memory data are available at DSM and also all my four modules(NI9421, NI9203, NI9265,NI9481) are listed there but there is not data from any of them!!(http://www.ni.com/gettingstarted/setuphardware/compactrio/systemmanager.htm) Even when I set value for my DO/AO modules the value still are not reachable at DSM or Output of modules!!
Do you know how I can solve it??
(5,888 Views)
I have exatelly the same problem! I have connected my Pt100 and  thermocouple right and I have no signal.
Does anyone know the solution?
I am working with a Ni crio 9022 frame with: 3x NI 9219 analog input, Ni 9472 digital output and a Ni 9263 analog ouput.
Tanks in advance.
(4,615 Views)
I have exactly the same issue, except I'm using cRio-9022 with EtherCat (9144). I have the following modules installed on the primary cRio: 9421, 9481. On the EtherCat (9144): 9208 and 9265 and 9205.
(3,541 Views)
