Use NI9881 on cRIO9042
Hello, which Linux System Image Version do I have to install on my cRIO 9042 to be able to use NI Industrial Communications for CANopen?
My Labview Version is 2019. Thanks
(1,061 Views)
I recommend using the latest available version for your cRIO.
  1. You can read more about installing software to your cRIO here: Install NI Software on Your CompactRIO Controller
  2. You can read more about software compatibility for cRIO/cDAQ here: Software Support for CompactRIO, CompactDAQ, Single-Board RIO, R Series, and EtherCAT
  3. Find a getting started tutorial here: Getting Started with CompactRIO Hardware and LabVIEW
(1,021 Views)
