Using Ethernet to transfer data using cRIO
Hi, I want to transfer data from cRIO to another device using the Ethernet port. The CompactRIO model I have is NI cRIO-9063, which does not have the PoE ports.
For example, I want to send data from cRIO to another cRIO using Ethernet port. Is it possible I could do so using TCP protocol? Are there any example VIs?
Thank you.
Message 1 of 12
(5,166 Views)
You can try using web services. But this won't work for streaming data. Here's a description:
https://www.ni.com/docs/en-US/bundle/labview/page/overview-web-based-communication-with-a-labview-ap...
https://forums.ni.com/t5/LabVIEW-Web-Development/Getting-Started-Series-Hosting-Web-Service-on-a-Rea...
Also, if you add both devices to one project, you can use network shared variables:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x2CMCAY&l=ru-RU
Message 2 of 12
(5,157 Views)
Message 3 of 12
(5,108 Views)
Hi. So I was able to send data from one computer to the other via Ethernet using UDP Example VI (not TCP).
However, the only way I could send the data was if I set the address in "UDP Write Block" from the Sender VI to 255.255.255.255.
If I set the Ethernet IPv4 Address that I set on the other computer, it would not work.
I have attached an image where it seems I'm getting the problem in acquiring the right address.
Please advise. Thank you!
Message 4 of 12
(5,093 Views)
UPDATE:
I was also able to send UDP data via Ethernet by auto-configuring its IP Address and using that IP Address. However, the same approach was not possible through TCP.
Message 5 of 12
(5,086 Views)
Launched examples for UDP. On one device, I send messages via UDP. On another device, I receive these messages. In my case, a similar example works.
Have you tried pinging between your devices?
Run->Cmd-> ping <IP_your_device>
Do you find the device you need when you enter the command "arp -a"? (Run->Cmd-> arp -a)
Are your devices on a shared subnet?
Message 6 of 12
(5,082 Views)
Can you send and receive data over UDP using a terminal? For example Hercules:
Message 7 of 12
(5,080 Views)
Hi karlin.
I was able to use UDP. And yes, I tested it with Hercules and it worked there as well, however, when I tried to replicate the same process via TCP, I was unable to send data. However, I believe this would work fine for my project. i.e sending data from cRIO to another device.
I will test that soon. Thank you for your help!
Message 8 of 12
(5,076 Views)
Hmm. When I make a remote device (in my case TPC2230) a server everything works.
But when I make my PC a server, it becomes impossible to establish a connection.
Perhaps this is the fault of the firewall settings. All ports on my PC are closed for incoming connections.
P.S. Please call me "Egor"
Message 9 of 12
(5,072 Views)
Hi Egor,
Same here. I even disabled the firewalls at both ends, the problem persisted.
Message 10 of 12
(5,068 Views)
