Using FIFOs or Saturation Arithmetics cause compilation error
Hi!
I'm using cRIO-9002, cRIO-9102 and LV7.1 . Problem: When I'm using FIFOs or Saturation Arithmetics in FPGA-VI, the Xilinx-compilator generate an error. Why? Any suggestion. I've pasted two error messages from the compilation below. I've also added a saturation add-example that generates the error.
//Ulf
Using FIFO:
Compiling vhdl file
C:/NIFPGA11/srvrTmp/LOCALH~1/TR78C1~1/rvi_fifo_write_325_29transducer_readaibuff
er_fpga.vhd in Library work.
ERROR:HDLParsers:163 -
er_fpga.vhd Line 7. Unexpected symbol read: _.
ERROR:HDLParsers:164 -
er_fpga.vhd Line 7. parse error, unexpected IDENTIFIER, expecting COMMA or COLON
Using Saturation Add:
* HDL Analysis *
Analyzing Entity (Architecture ).
Set user-defined property "OPTIMIZE = off" for signal .
Entity analyzed. Unit generated.
ERROR:Xst:761 - C:/NIFPGA11/srvrTmp/LOCALH~1/ADD_31~1/rvi_add.vhd line 401: No default binding for component: . Ports do not match.
Total memory usage is 49432 kilobytes
ERROR:Xflow - Program xst returned error code 6. Aborting flow execution...
(4,268 Views)
Ulf,
Are you using a localized (non-english) version of LabVIEW?
Chris
(4,248 Views)
@cfarmer wrote:
Ulf,
Chris
Hi Chris!
No, I'm not using localized version of LabVIEW. The error is however found! For some reason, the compiler doesn't like that you change the VI-Server options in LabVIEW. "Exported VIs"-list have to be blank. The strange thing is that the compiler works fine, as long as there are no FIFOs or "Saturation"-VIs in the code.
//Ulf
ps. Have you noticed that "complex" data structures behaves strangley in the FPGA code? For instance, I had the "calibration"-cluster inside a cluster together with a boolean indicator(see below).
LSB Weight
Offset
<\Calibration>
CalibrationReady
<\Cluster>
It didn't work so good... It wasn't updated with the values. When I removed the "outer" cluster, everything works fine. Seems like LabVIEW-FPGA have some bugs...
ds.
(4,246 Views)
The data structure got messed up in the reply above. Sorry
{Cluster}
{Calibration}
LSBWeight
Offset
{\Calibration}
{\Cluster}
//Ulf
(4,245 Views)
{Cluster}
{Calibration}
LSBWeight
Offset
{\Calibration}
{\Cluster}
//Ulf
... Too early in the morning, forgot the CalibrationReady-indicator.
{Cluster}
{Calibration}
LSBWeight
Offset
{\Calibration}
CalibrationReady
{\Cluster}
(4,241 Views)
