Using Mikron m770s IR sensor with labview
PollardVT was referring to the requirement that AI Sense must be connected to AI GND when using the SCC-68 with an Analog Input SCC module (see manual).
If this does not apply to your situation, it would probably be best to make a new post to the appropriate forum for your hardware (e.g. Signal Conditioning if the issue is specific to using SCC modules, or Multifunction DAQ if the problem is a general issue with using or connecting to an NI DAQ product).
Best Regards,
John Passiak
Message 11 of 13
(1,392 Views)
I posted my question with this title :
SCC-68 differential or RSE or NRSE
in Multifunction DAQ
  • 0 Kudos
    Message 12 of 13
    (1,387 Views)
    Thanks, I found the post here.
    Best Regards,
    John Passiak
    Message 13 of 13
    (1,382 Views)
