Using a Ni 6259 to voltage signal at 1MS/s sample rate multi-channel.
I want to read 8 signals of voltage from a device at a 1MSample/s to each channel using a NI 6259. Can I do it?
The manual say to me the following:
"1MS/s multi-channel (agreggate)". What it means?
The sample rate will be divided to each channel?
The hardware has just one ADC.
(3,290 Views)
1 channel you will have 1,25MS/s, but it will be to use more channel than will be divided the total value for the amount of canals used total value for the amount of canals used.
(3,283 Views)
