Using arduino DUE and MPXV7002DP and LABVIEW to get pressure data
Hi all, I apologize if this has been asked before but i tried looking for solutions but i have found none. I have no experience in using arduino, labview or anything electrical(mechanical engineer here) and thus would need quite a detailed answer if any.
I would like to take pressure readings with MPXV7002DP. The analog output 0-5V would then be transmitted to the ARDUINO DUE and thus transmit the pressure readings to my computer through MATLAB.
May i know if this is doable using labview, or should i stick to arduino code.
(3,640 Views)
Hi plshelpme11,
You can use LabVIEW with an Arduino with a toolkit called LINX.  I'm not sure about the Arduino Due specifically but many Arduino and similar boards are supported.  There are also some good LabVIEW tutorial videos as well.
For LabVIEW tutorials, go here.  Once you understand how LabVIEW works you can check out the LINX tutorials that show you how to use LabVIEW with Arduino, Raspberry Pi, and many other devices.
After you take a look at some of those tutorials you can ask questions on the MakerHub forums.
Ken
(3,573 Views)
