Using more than one stepper motor with one cRIO
I am using two stepper motors for my project. I have one stepper motor, Stepper motor drive P70530, Stepper motor C series module NI9512.
I am planning the other motor which is intended to be controlled by the same cRIO.
How can I do the setup for two motors? Do I need two SMDs? Do I need two modules NI9512? Pl help.
(2,588 Views)
This link might help.  I have not read it in detail so it might not answer:
https://forums.ni.com/t5/Motion-Control-and-Motor-Drives/P70530-SDN-Stepper-Drive-stepper-motor-cont...
If your current requirements are not too high, an alternative is to build your own or by a board that has a TMC controller and control that from a DIO module
(2,555 Views)
Thanks Michael
(2,511 Views)
