Using myRIO analog output (C/AO0) and analog input (C/AI0)
Hi everyone. I'm working on myRIO. I want to apply a simulate signal of triangle (-1V  to +1V) to my sensor through analog output (C/AO0). Then, I want to check the applied signal using analog input (C/AI0) display on waveform chart. The problem is, I don't get the triangle (-1V to +1V) signal back, I only get 1 value only. The VI as attach below. Is there any ways to get the desire result. I really need help on this. I have try to work on this for almost 2 weeks and try to search every where but none really help. TQ
(2,544 Views)
The input for analog output says (1 sample) so it's going to output one point (probably the first point in the waveform. On a compact RIO what you'd want to do is to transfer the whole waveform through a Host-To-FPGA stream. There's some pretty good examples here:https://www.ni.com/en/support/documentation/supplemental/09/ni-compactrio-waveform-reference-library...
There is probably an easier way to do that with the myRIO though but I'm not familiar enough to know what example to point you to.
(2,509 Views)
