06-13-2008 02:27 AM
06-16-2008
08:49 AM
- last edited on
04-18-2025
02:32 PM
by
Content Cleaner
Hello Torsten,
please look at the Labview RT Modul Help.
It depends on the LV version.
For example in the 8.2 version you set it in the project explorer.
You can create a stand-alone real-time application using the LabVIEW Application Builder and set the application to run when you power on an RT target. You can create multiple build specifications that configure the settings of stand-alone real-time applications under an RT target. However, you can set only one stand-alone real-time application as startup for an RT target.
Complete the following steps to set a stand-alone real-time application as the startup application for an RT target.
Kind regards,
Elmar
