Veristand deploy error
I used joystick input to read steering. then build the .so with veristand_linux_64
when I deploy the model  ,it failed. It shows:
Possible Reason:  Veristand could not complete one or more requests, because a target is offline
But the PXI is online
 matlab 2018a  , veristand 2019
Can u tell me the reason?
Thank u all
(1,544 Views)
Could you please share the screenshot of the error?
Best regards
(1,503 Views)
(1,494 Views)
Are you able to deploy an "empty" project? You can create and deploy a new VeriStand project with no models or anything but just one or two WorkSpace objects reading System Channels like the Actual Loop Rate or the HP Loop Duration just to make sure VeriStand is working fine.
Regards
(1,423 Views)
