Very large array cause the program to slow down
Dear Sir or Madam,
I am writting an array of data to my AO board to generate analog signal with LabView.Because the time resloution is high(200usec),and the whole time is long(~100sec),the data array becomes very large (8 X 5*10^5) (8 chanels),and the delay time between starting runing and the signal really output is long(~20sec).
I wonder when some vi (ex.build array.vi..) is dealing with large array,it delays the speed of running because the number of loops I am using is independent of array size.
How could I overcome this problem?
Is adding some RAM helpful?
Thank you for your kind help!!
(3,509 Views)
dont use build array functions in a rt loop, create the array before and use
replace array subset, then it should work.
for the date u want 2 save is 32mb ram more than enough.
gl&hf
ventilator 😉
"cooler" schrieb im Newsbeitrag
news:506500000008000000F1600000-1031838699000@exchange.ni.com...
> Dear Sir or Madam,
(3,509 Views)
