Watchdog doesn't reset cRIO
I would like to use watchdog functionality on my cRIO (9031). I used "watchdog configure" vi, set small amount of timeout and never use whack vi. Watchdog expired but didn't reset my cRIO. I have installed appropriate drivers on cRIO. Do I have to enable watchdog functionality somewhere ? I tried to use an exmaple but it also didn't reset cRIO.
Kamil
Message 1 of 9
(4,997 Views)
There is a cluster input on the Watchdog Configure.vi called "expiration actions".  You should just have to set the "reset" boolean to TRUE.
Message 2 of 9
(4,991 Views)
I did it 🙂
Message 3 of 9
(4,986 Views)
my configuration:
Message 4 of 9
(4,960 Views)
I guess it helps to read the help file:
"Configuring a watchdog object does not start the watchdog counter.  Use the Watchdog Start VI or the Watchdog Whack VI to start the watchdog counter."
So Whack the watchdog after configuring and that should get the counter started.
Message 5 of 9
(4,956 Views)
I was using whack also. As I wrote the watchdog expires (status from whack) but doesn't restart device. I have tried it with NI example - Watchdog - RT engine and it doesn't work.
Message 6 of 9
(4,953 Views)
Hi Kamilk,
why dont you just share your demo project with us, so we can have a look. It is easier to look at the whole thing then to check every possible misstake in writing.
Christoph
Staff Applications Engineer
Certified LabVIEW Developer (CLD), Certified LabVIEW Embedded Systems Developer (CLED)
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved
Message 7 of 9
(4,903 Views)
In attachement an example which I used.
Message 8 of 9
(4,901 Views)
Hi!
I just tested it myself to be on the safe side with a cRIO 9033 (which is pretty similar) and it works as a charm. Perhaps you didnt activate the "reset target on expire" button before the VI was run?!
Christoph
Message 9 of 9
(4,875 Views)
