What are the System requirements for running a model in fpga 9014 ?
Hello together,
I have a simulink model which I want to run on a cRIO 9014 (OP is VxWorks) device. The model contains CAN Inputs and Outputs.
I know that a must convert the model into a shared library, than upload the converted model to the fpga and use a CAN modul to assure the CAN communication. The control of the fpga VI happens with a host VI via simulation interface toolkit on my Windows computer.
Now I want your help first concerning the system requirements on the cRIO and on my Windows PC : which software I need to install and where ?
Thank you very much !!!  :smileyhappy:
(3,704 Views)
Have a look at this tutorial:
Getting Started with CompactRIO and LabVIEW
Post back if you have any questions after reading through it.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(3,700 Views)
Thank you for your reply !
Actually my problem concerns now the simulation interface toolkit (and his system requierements) and his interaction with the fpga.
More precisely what do I need to download a simulink model on the fpga and how to link my CAN inputs/outputs in the model with the CAN module inputs/outputs ?
thank you in advance !
Message Edited by Jarod3391 on 04-23-2009 09:04 AM
(3,696 Views)
I don't think it's really straightforward. Have a look at this post by James:
http://forums.ni.com/ni/board/message?board.id=170&message.id=371481&requireLogin=False
Adnan Zafar
(3,690 Views)
