Where is ni_emb.dll suppose to be located for RT LED; Can I reload RT LED vi?
I am currently trying to control the user LED on a 9004 RIO.  However, when originally loading the RT LED vi it could not find the file, ni_emb.dll, in the right location.  I searched my computer and found it.  When i tried to load the program again and it asked for the location, i browsed the window it provided til i found it.  Now when i load the vi, it states "Call Library Function Node 'LedInput': Node not supported in current target", "Call Library Function Node 'LedOutput': Node not supported in current target"  Is there a way i can reload the RT LED vi. Thanks
(4,270 Views)
MLSAllstar,
This error occurs when the VI has not been targeted to the Real-Time controller. RT LED.vi will work correctly if added (or added to a calling VI) under the Real-Time controller through the LabVIEW project (assuming you are using LabVIEW 8.x).
Cheers.
| Michael K | Project Manager | LabVIEW R&D | National Instruments |
(4,255 Views)
