Where is the stop-start-daemon in the latest NI Linux Real-Time System?
Not using LabView. Have a C++ application installed on the cRIO for data collection/processing. The cRIO runs autonomously so the application needs to start when the system boots.
There is an excellent tutorial in the knowledge base, "Tutorial: Installing Startup Scripts on NI Linux Real-Time", that shows how it is done and that I have been using successfully up to now.
Just installed the latest NI Linux Real-Time System (2023 Q2) and the startup script has stopped working.
It seems that the bit that makes it work is a call to start-stop-daemon (copy of command below).
On looking for a reason why the script had stopped working I looked in the /sbin directory and the start-stop-daemon is not there!
Can anyone tell me where it has gone (different directory), or has the command now got a new name?
/sbin/start-stop-daemon --start --pidfile $PIDFILE \
--make-pidfile \
--chuid $USER --exec $DAEMON
(2,003 Views)
Accepted by topic author idc12
I found it.  It has been moved to /usr/sbin
(1,965 Views)
