Which processes or threads uses the Shared Variable Engine (SVE)?
I have nearly no experiences regarding to programming a cRIO. There are some things I do not understand.
Hopefully someone can help me to understand the work of the Shared Variable Engine (SVE).
I know that the SVE just works if a Shared Variable is used in a process of a VI but why? So now my question is, which processes or threads uses the SVE?
best regards, MS7.
(5,854 Views)
Prior to LabVIEW 2012, NI Variable Engine is listed as National Instruments Variable Engine in Windows Services.
When a shared variable is deployed to a real-time target, there is no physical location where the shared variable or its library is stored on the target. The variable is a part of the shared variable engine installed on the controller and will stay resident there until un-deployed.
(5,842 Views)
OK, I understand, thanks for the reply.
But ...
I have a WHILE-loop in my VI and when I decrase the delay for the loop I get more and more false values at the beginning of the test and data loss during the test.
I mean with a slow loop (e.g. 500ms) I get all values in a "synchronous" way. In a fast loop (e.g. 10ms or faster) the VI is not synchron and I loss some data.
That is why I ask whether the SVE needs also time to manage the Shared Variables or what is the reason for this behaviour?
best regards, MS7.
(5,829 Views)
could you please post your VI or a screenshot, so that othe forum users could have a look on it?
(5,821 Views)
Here my VI, I send the data from the cRIO to the computer.
It is just a counter but you see the differences between the delay times.
First picture show in fast loop I lose the first values. In this case the numbers 1 - 7. And additional I do not understand, from where are the values which resides in the lines 1 - 11?
Second picture show in slow loops I do not lose data but in this case, from where are the values resides in the lines 1 and 2?
(5,818 Views)
